Discussion topic: Netflix
Message posted on 04 Apr 2023 05:42 PM
Netflix
I cannot kog into Netflix, the circle keeps going round but doesn't log in.
I've tried turning everything off and restarting which worked once after trying a few times but not anymore
Message posted on 04 Apr 2023 05:47 PM
Re: Netflix
Hi @Limes+Road
Message posted on 04 Apr 2023 06:07 PM
Re: Netflix
Thank you for replying so quickly
