Discussion topic: Sky TV connection
This message was authored by: Jamie6789
Sky TV connection
My sky has not been working for past 24 hours. I've tried to turn off from mains. However still not connecting it says no signal
Re: Sky TV connection
Is the TV on the right HDMI input? Is the power light green ?
Avatar for Jamie6789
Yes I believe it is
And the green light on the Q? Does it do the blue light glow thing when it powers up?
@Jamie6789 does it say no signal or no satellite signal ?
yes it's saying no satellite signal on my tv so the sky screen doesn't even come up
Can you post a photo of this please?
Hi @Jamie6789
Your message is No Signal (and not No Satellite Signal)
Check that the Q box is indeed connected to input HDMI 1 on your Television.
Also check the the HDMI cable  is securely fitted at both ends.
Also is the Q box on with green led?
If it is press Home 1 0 8 0 Home
on the Q remote.   This will set the Q box to standard 1080i resolution.
