Discussion topic: Main tv will not switch on although the second tv is working okay
This message was authored by: Johnmackie
I am using control but cannot switch on main tv. Have changed batteries in control but this has made no difference
Re: Main tv will not switch on although the second tv is working okay
Hi @Johnmackie
Have you tried switching the Main Q box by pressing the Standby button on the front of the Q box (the Amber led).
If this works
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Johnmackie
Level 0 icon
Have tried to reboot to but the green line is on the tv box but nothing else is happening.
Hi @Johnmackie
A reboot restarts the Q box but also puts in into standby with an Amber led.
Did you get the onscreen message after the reboot and how did you get the green led?
