3
This discussion topic has been answered Discussion topic: Netflix
This message was authored by: Farrian
Netflix
Hi,
I have NETFLIX on my TV as part of my subscription.  I also want to watch it on an IPad - my subscription includes this. I can't remember my password.  If I reset the password so that I can watch it on the IPad, will it affect the TV ie will I have to log in again on the TV?
Thank you.
This message was authored by: Chodley Answer
Re: Netflix
Suspect the TV will maintain a valid token for a while and then will require a login with the new password one day.
Re: Netflix
@Farrian wrote:
Hi,
Thank you.
@Farrian I would think you will have to seeing as you will have changed the password
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Netflix
@Farrian wrote:
Hi,
Thank you.
Hi @Farrian
Before you change your password I would suggest you log out on the TV.
Re: Netflix
