14
This discussion topic has been answered Discussion topic: Netflix wont play anything
This message was authored by: Nettie56
Netflix will load but when I select a programme it will not give me the option to play. This is on my main skyq box, works fine with my mini box. Tried chatting with Netflix but couldn't resolve issue. Can anyone help?
Avatar for Nettie56
This message was authored by: Nettie56 Answer
Re: Netflix wont play anything
Update to my earlier post. Sky have just called me and said Netflix has just informed them that there was a software update error and they are working to fix it ASAP. They have been inundated with calls regarding this, alot of people having the same issue. Hopefully will be up and running soon.
This message was authored by: Hillwalker2
Having same issue, cannot get option to play on SkyQ main box, mini box will play selected item as soon as selected.  But still does not give the option to select play.
Avatar for Nettie56
I've been on the phone to Sky and Netflix most of the morning. Still.not working. They are ringing me back later this afternoon, dont think they have a clue whats wrong.
This message was authored by: bobby999
Have the exact same problem and based in Wales. Had it since this morning and tried the usual steps. It must be a problem with them
I've tried resetting Qbox and no difference, can't call Sky as I have lost my voice so having to try online with no success.
This message was authored by: AB99
Same here. Watched it early today - this morning but no option to play anything now. Just displays show details. Ok on my iPad app so just via main Sky Q box
A
Avatar for Nettie56
This message was authored by: eperry
Thank you so much for sharing this! Ours isn't working either but thank you for chasing!!! Hopefully it will be fixed soon!
Thanks for update, all working well now.
Is anyone else's working again? Mine doesn't seem to be!?
Avatar for Nettie56
Mines not working yet 😕
Mine is still not working yet
I reset the box (switched off at the wall and on again) and it's working now! Maybe try that!
Thank you eperry. Just turned it on and off and its back working.
Avatar for Nettie56
Yes! Unplugged for 30 seconds and hey presto! We're back on 😊
Answered - Go to Answer
