Discussion topic: Netflix on mobile devices
Message posted on 26 Aug 2023 01:53 PM
I recently added my Netflix account to my sky q account.
I can watch netflix using the Sky Q box. All good there.
However, it seems like my old netflix login has gone and i am not able to watch on my ipad / iphone.
How can i get this working again?
Message posted on 26 Aug 2023 01:58 PM
Re: Netflix on mobile devices
If you have Netflix on your Sky account and you have the correct package that allows you to use extra devices then you should be able to use your Sky login details to access Netflix on your mobile devices.
These are the packages:
Ultimate TV includes the Netflix Basic plan (1 screen + SD) as standard
You can upgrade to Netflix Standard (2 screens + HD) by adding the HD pack
You can upgrade to Netflix Premium (4 screens + UHD/HDR) by adding the Ultra HD pack (requires the HD pack first)
Message posted on 26 Aug 2023 02:13 PM
ah, i think i only have HD for movies.
That may explain it.
Message posted on 26 Aug 2023 06:10 PM
Hi @caesarome
The new bundles for Sky Q all include HD as standard to align with Netflix's own pricing.
ie
Assuming you subscribe through Sky
Sky Ultimate TV includes the Netflix Basic plan (1 screen + HD)
You can upgrade to Netflix Standard (2 screens + HD) by adding the HD pack On Sky Q.
You can upgrade to Netflix Premium (4 screens + UHD/HDR) by adding the Ultra HD pack (requires the HD pack first) on Sky Q.
You shouldn't have a new and old login.
On all devices (incl mobile) you should use the same login as you use for Sky.
Also be aware that simultaneous number of screens in use is dictated by your Sky Q package as shown above.
Message posted on 13 Oct 2023 01:44 PM
So if we've got the 'Netflix Basic plan', can we access Netflix on a mobile?
I don't need 2 screens simultaneously, I just need that the 1 screen I want to stream on is the mobile, is that possible?
Message posted on 13 Oct 2023 01:48 PM
Yes you can access Netflix on any device but are limited to one device at any time
I use my TV's own app (or a Firestick in my bedroom) rather than the SKY Q box
Message posted on 13 Oct 2023 02:19 PM
And do you know if I have to do anything else specific?
In my iphone 'Sky Go' app I cannot see anything specific regardin Netflix channels, and trying to log into Netflix (either on the phone or on a PC browser) they don't recognise my Sky email user/password.
Is there anything else one needs to do to find that Netflix content somewhere?
Message posted on 13 Oct 2023 02:26 PM - last edited: 13 Oct 2023 02:28 PM
hi @Mickael you don't use SKY Go to access Netflix.
Netflix has it's own app that you should download (if not there already) and login into it using the same email & password credentials as used for Netflix on the SKY box
Message posted on 13 Oct 2023 09:44 PM
Thanks, I was trying to set things up after having the account active and working with the Sky Go app for now, while waiting for the Sky box coming next week.
I'll retry once I see it all working on the Sky box, in case there's something done during that setup process which has not been done yet, neither with the Account activation nor the Sky Go setup.
Message posted on 13 Oct 2023 09:49 PM
Ah, I think you do need to set it up initially via the SKY Q box - during which I think you will be asked to set up the account credentials (email & Password) - it is separate to SKY Go
Message posted on 14 Oct 2023 01:36 PM
Just follow up. Indeed, thanks for that.
Got my Sky boxes today, had to set Netflix up and link them there first and after I could stream on the mobile app too.
Many thanks.
Message posted on 14 Oct 2023 01:52 PM
Many thanks.
Glad you are now all set up & thanks for letting us know.
Message posted on 09 Jan 2024 12:51 AM
Hi there, I have Ultimate tv add on for Netflix. But also have HD & Ultra HD - yet my phone netflix is still SD. Shouldn't this be HD also?
Message posted on 09 Jan 2024 01:03 AM - last edited: 09 Jan 2024 01:07 AM
@M12R wrote:Hi there, I have Ultimate tv add on for Netflix. But also have HD & Ultra HD - yet my phone netflix is still SD. Shouldn't this be HD also?
Yes I think so (though it changed to soecific boosters for netflix recently but they should be honouring the older system for existing customers)
how do you know it's SD? I don't see anything on the content on my phone that specifies. I've got a video quality option of Standard and Higher (though I don't use higher on the phone as download size would grow)
Message posted on 09 Jan 2024 04:04 AM
If you goto; App Settings - Playback Specifications.
It will show Playback, Maximum playback resolution;SD
