Discussion topic: Netflix on Sky
Message posted on 02 Mar 2023 06:45 PM
Netflix on Sky
I upgraded to Sky Q today and agreed to Netflix through Sky. I have changed my mind and want to keep it separate. Do I need to cancel it on Sky I haven't logged into it.
Message posted on 02 Mar 2023 07:00 PM
Re: Netflix on Sky
Hi @Suzyt
If you ordered Netflix (Ultimate TV add on) through Sky then you certainly want to contact Sky to make sure it is cancelled.
Message posted on 02 Mar 2023 07:15 PM
Re: Netflix on Sky
@Suzyt Just wondering why you wish to keep them separate. I have mine via Sky but never actually use the Sky apps version, still use the TV's own apps as I "just like them" better.
Hope you get this sorted out for you.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 03 Mar 2023 10:14 AM
Re: Netflix on Sky
I access netflix via Apps on the Sky menu. Apps is not an option on Skygo. How do I access Netflix when I am abroad?
Message posted on 03 Mar 2023 10:20 AM
Re: Netflix on Sky
Hi @Furzelands
Assume you have Netflix App loaded on your mobile device.
Message posted on 03 Mar 2023 11:11 AM
Re: Netflix on Sky
@Ecosse wrote:@Suzyt Just wondering why you wish to keep them separate. I have mine via Sky but never actually use the Sky apps version, still use the TV's own apps as I "just like them" better.
I only really worth keeping it separate if you have Netflix Premium and only the HD add-on. If you have the UHD pack as well it's cheaper to move Netflix to Sky.
In my case I already had Sky Q with HD/UHD so switching my Netflix Premium plan to Sky is costing me £6 instead of £15.99.
