4
This discussion topic has been answered Discussion topic: Netflix not loading
This message was authored by: TheFaceman
Netflix not loading
Last couple of days Netflix won't load. Just get the red twirling circle.
On a Sky Q box.
Have restarted box and router with a full power off power on.
Have gone into setting menu with 001 and reset apps.
Netflix still not working. I see other people with similar issue but no answer or fix other than 'is it Sky Q'.
is there an issue with Netflix app on Sky Q?
Re: Netflix not loading
@TheFaceman
This is what you need to do:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4691069/highlight/true#...
You can let Sky know about this via this form - https://forms.office.com/e/VGr0tUpv67
@TheFaceman
Avatar for TheFaceman
Level 0 icon
Thanks @caesarome that has sorted it 👍
This message was authored by: eemeeee
Load other Apps within Sky past their splash screen then try Netflix again.
Can sometimes take 2 or 3 attempts...
This message was authored by: Roisin23
Currently trying this but how can I log out of Netflix on the tv app if it won't let me into it in the first place?
