Discussion topic: Cannot connect sky q mini box to main box
Message posted on 12 Aug 2024 12:27 PM
Hi . Re mini box. I get as far as getting the middle light gone green and the the right one flashing reddish. I then go to main q box and press button on right of green light until it flashes. So now both are flashing, l wait a couple of minutes then the tv upstairs with the mini box says it can't connect.
Message posted on 12 Aug 2024 12:40 PM
Re: Cannot connect sky q mini box to main box
Hi @Mike7522
Don't know what you mean by middle light gone green. There is no middle green light on a mini. Unless you are referring to a Sky Q WiFi booster.
If you just have the main Q box and a mini then First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 12 Aug 2024 07:45 PM
Thank you very much for the advice. I've tried what you said and it's all working ok now. So yes I am very grateful for your help. Mike
