Discussion topic: Netflix not loading
Message posted on 27 Jun 2024 11:04 PM
Netflix not loading
Netflix has stopped loading on one of my tvs its never been a problem before, anyone know why this is happening. Its runningvof a mini box
Message posted on 27 Jun 2024 11:21 PM
Re: Netflix not loading
Not any help, but just to say that mine's also been not loading for a few weeks now. On occasion it does work, but more often it doesn't. The Netflix app works on my TV, indicating that it's the Sky box version that has the intermittent fault.
Message posted on 27 Jun 2024 11:27 PM
Go to 'Settings' on the Sky screen and just highlight it. Press 001 then 'enter' and you will see that you can reset the apps. Worth a try!
Message posted on 02 Jul 2024 04:45 PM
Great idea but still working, it was worth a go though
Message posted on 07 Jul 2024 08:00 PM
Still happening for me, would be good for Sky to post a solution because at this point its becoming frustrating
Message posted on 07 Jul 2024 09:31 PM
@Jon105 have you read the thread below
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388
Message posted on 08 Aug 2024 07:38 AM
Following a Sky Broadband upgrade I had the same problem.
i disconnected the modem, televisions, Sky Q Box and Sky Mini Box.
I lleft it a few minutes a few minutes before reconnecting and it has solved problems. Fingers crossed that this will continue without any further problems.
