Discussion topic: Netflix has not load on my sky app for over a week now
Message posted on 02 Aug 2024 08:21 AM
Netflix hasn't loaded on sky app for over a week. All other apps work fine.
what has happened?
Message posted on 02 Aug 2024 08:25 AM
Re: Netflix has not load on my sky app for over a week now
When you started writing the subject line for this post you would have seen a series of suggestions about other threads on similar topics so that you can check those before asking the same question hundreds of other people already asked. One of those suggestions, which is near the top of the list on here, is hundreds of posts long so easy to find, tells you that Sky have identified a bug they are working with Netflix to fix, and has a fairly reliable workaround/solution in it which is re-stated in the last couple of pages.
