8
This discussion topic has been answered Discussion topic: Netflix fails to load
This message was authored by: Leemand
When I go to the Netflix app on my Sky Q box, all I get is a spinning wheel, and it will not load. Any help please
This message was authored by: Quoman7 Answer
Re: Netflix fails to load
Hi @Leemand Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Avatar for Leemand
Thanks, works well now
This message was authored by: popeye100
Every time almost we go to use the Netflix app it fails to load, sometimes after the reboot of router and sky q box it works but occasionally not. No problem with prime or the other apps on sky q
any advice apart from switching to the full netflix service on the smart tv
https://helpforum.sky.com/t5/Sky-Q/Netflix-app-crashing-won-t-load/td-p/4327487
basically, no, not yet. Use the app on the TV.
This message was authored by: SallyM1
Hello
I've tried the reboot wice and still netflix just shows a circle spinning round. I've also tried to get netflix directly through the app
Okk thanks I've got the netflix back for now
This message was authored by: Linda4321
Tried unplugging etc... no joy!
Hi @Linda4321   The current problem does not relate to this old one, the new problem is only 107 pages ...
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388/page/107
