Discussion topic: Netflix and Sky Q
This message was authored by suebh This message was authored by: suebh
Netflix and Sky Q
Does anyone still have issues with Netflix and Sky Q? Only happens on the main box. Minis are fine. It's the usual red circle and doesn't load. Sometimes and error pops up . Sometimes the reset works and other times it doesn't. There is obviously a bug with the app integration. Netflix works on all TVs if you don't access through Sky. Are Sky looking into this does anyone's know?
Re: Netflix and Sky Q
Hi @suebh
Not a general issue and therefore not a bug that Sky would be looking into.
When you say a reset sometimes works is this just a reboot you are doing.
If so try a Reset Settings in the Q box hidden menu.
