Discussion topic: Need to cancel a order
This message was authored by: Mini221
Can I cancel without ringing been on the phone for an hour
Re: Need to cancel a order
If you login to your account at Sky.com on a web browser, click on your name at the top right and then you can select "My Orders".
Not all orders can be cancelled this way but it would be the best place to check, or in the My Sky app if you have it.
@Mini221
I'm afraid not as you will need to call but I should imagine the phone lines will be busier than usual due to the problems this morning with Sky Q so you will need to just hang in there on the phone and say nothing when asked any questions by the bot,
