Discussion topic: NETFLIX speed check 30mbs
Message posted on 27 Apr 2026 03:52 PM
I've been getting a bit of buffering when I watch a 4k film. My TV netflix app says it receives 141mbps (home broadband is 150mbps)
Yet my sky Q box, which is brand new today as a replacement says 30mbps.
Any ideas. Are the boxes limited? I don't have any cables to try hard working it in.
Message posted on 27 Apr 2026 04:14 PM
Re: NETFLIX speed check 30mbs
You're much better off using your TV's Netflix app as it will be optimised to give you the best experience on your TV.
Sky Q is decade-old technology and the apps are limited in the formats that can be output. Your TV may have Dolby Vision or HDR10+, neither of which Sky Q can output.
Message posted on 28 Apr 2026 08:29 AM
@JONNY2015 wrote:I've been getting a bit of buffering when I watch a 4k film. My TV netflix app says it receives 141mbps (home broadband is 150mbps)
As above, use the TV's built in Apps where possible as the picture and audio are better in a modern TV. For reference my Q box gets around 50Mbps+ which sits below the TV which gets 240Mbps (both via WiFi)
If not possible then try repositioning the Sky router or Q box to give it line of sight.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
