Discussion topic: Password
Message posted on 28 Apr 2026 09:29 AM
Password
How can I reset my password to connect my QBox to the WiFi.
for some reason it won't let me find WiFi connection with original password
Message posted on 28 Apr 2026 09:46 AM - last edited: 28 Apr 2026 09:46 AM
Re: Password
@Flod1 wrote:How can I reset my password to connect my QBox to the WiFi.
I'm not sure changing the password will help you do that and you will lose connection to everything else. If you still want to go ahead, which router do you have (presuming it's a Sky router)?
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
