Discussion topic: N
This message was authored by: Maxwell4
N
Need to speak directly try to a human being!!!!
Avatar for Maxwell4
Level 0 icon
Re: N
Need to speak directly to your technicisn
Re: N
@Maxwell4  Then you need to call Sky.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Re: N
@Maxwell4
You'd need to call for that. Is it something we can advise on?
Avatar for Maxwell4
Level 0 icon
Re: N
Speak directly to human being!!!!
Re: N
You've been advised in 2 post how to do that,  repeating your question won't make that happen.
Re: N
@Maxwell4
Even 4 exclamation marks don't get you any closer to an agent (when calling Sky you speak to an agent rather than a technician).
You have been given the correct methods of contacting Sky although the phone lines are probably closing any minute.
