Discussion topic: Screen just says accessibility on sky Q settings or skip but remote does not work now?
Message posted on 14 Jul 2024 01:48 PM
Sky q box is stuck on Accessibility on sky q
offers settings or set up later cannot do anything as remote won't work now I have changed the batteries to check still does nothing
Message posted on 14 Jul 2024 03:14 PM
Re: Screen just says accessibility on sky Q settings or skip but remote does not work now?
Same! Literally only the hdmi button works
Message posted on 17 Jul 2024 07:14 AM
Me too. Any ideas what to do?
Message posted on 17 Jul 2024 07:45 AM
Did you manage to fix this?
Message posted on 17 Jul 2024 07:58 PM
Have you managed to sort this? We are having the same problem
Message posted on 17 Jul 2024 08:10 PM
Have you tried resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 17 Jul 2024 08:36 PM
I managed to use the Sky go app remote to get myself to settings then I had to do the reset remote and now working finally
Message posted on 17 Jan 2025 10:03 PM
I've tried but my remote still isn't working this isn't right come on sky help
Message posted on 12 Apr 2025 09:57 AM
Had the same issue but with my second box in another room. If you go to your main box, press the sync button and then press the sync button on your second box it should connect and then work.
Message posted on 12 Apr 2025 10:30 AM
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 21 May 2025 05:03 PM
Thank you! That just solved my problem 🙂
Message posted on 10 Jan 2026 09:06 PM
Helped a lot
