Discussion topic: Technical difficulties with sky tv
This message was authored by: Nillo
We are having problems with our sky tv
Re: Technical difficulties with sky tv
@Nillo  can you give us an idea of what the problem is ie  what are you seeing on screen ?
are there any error messages ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Nillo
If you are seeing a Technical fault on your channels Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
