Discussion topic: My sky won't connect to the hub
This message was authored by: Sarah378
My sky Q won't connect to the router. I've tried to reset it using the wps button on the router too
Re: My sky won't connect to the hub
Hi @Sarah378
This message was authored by: shazza3uk
Hi I have the SKYQ tv box which is also not connecting to my new full fibre router.  There is no WPS button on the hub.  There is one on the SKYQ box of which have have pressed in and still nothing I can't connect to any Catch Up TV, or My Sky.
Do I need one of these SKY Q Boosters and can one be sent through.  Is there a contact telephone number please I can use rather than the virtual assistant which drives me nuts.
