Discussion topic: My sky remote isn't working, I have requested one online and it has been rejected.
This message was authored by: jonnyamery1
The phone number it gave me sent here.
Re: My sky remote isn't working, I have requested one online and it has been rejected.
Hi @jonnyamery1
First reboot your Q box.
Then with the Q box on with green led try completly resetting your Bluetooth remote.
Failing all the above
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
@jonnyamery1
In addition to the advice from @oldfella you can always purchase a new Sky Q remote from a retailer or larger supermarket.
