Discussion topic: Remote control
This message was authored by: Kerry113
Remote control
Hi the remote for my sky box will not work and I've tried a remote from a different room and that won't work either so you can scroll or change a channel and you have to manually turn the box on
Re: Remote control
Hi @Kerry113
First reboot your Q box.
Once the Q box is completely back up and running
