Discussion topic: My sky q box says that it cannot detect the viewing card.
This message was authored by SamFran71 This message was authored by: SamFran71
I have moved my sky q box and it now says it cannot detect the viewing card.  I have re-inserted many times and rebooted but no change
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: My sky q box says that it cannot detect the viewing card.
Try cleaning the card's contacts with a soft cloth.
If it won't work then you may either need a new card or new Q box.  Either will require a call to Sky...
I am just another Sky customer and my views are my own
Hi @SamFran71
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
