This discussion topic has been answered Discussion topic: My sky q box has no sound
Message posted on 01 Jun 2024 07:31 PM
My sky q box is working as expected but has no sound, also tried the apps within sky and there is no sound on those either however, my tv sound is working. This is the 4th time this has happened and last time took days to come back
Message posted on 01 Jun 2024 07:41 PM
Thank you! I found another suggestion to unplug both ends of the hdmi cable and power off the tv and sky box and it seems to have worked!
Message posted on 01 Jun 2024 07:35 PM
Re: My sky q box has no sound
Hi @Kathryn83
Message posted on 14 Sep 2024 04:45 PM
No sound , have tried all hints and tips but still no sound
Message posted on 14 Sep 2024 05:19 PM
Message posted on 29 Jan 2025 09:30 PM
This resolved mine issue after having tried everything else. So simple, but something I completely overlooked. Thank you buddy 😁
