Discussion topic: My sky mini box won’t connect or reset
Message posted on 26 Aug 2024 09:26 PM
Sky mini box won't reset or connect
Message posted on 26 Aug 2024 09:29 PM
Re: My sky mini box won’t connect or reset
Hi @Sand47
Reboot the mini as above.
