Discussion topic: Sky box or remote not working
This message was authored by: Yes4
Sky remote and box are not responding even after trying to change the batteries of the remote and taking the sky card out of the box and we have checked the wire connections and it seems that it's all intact. This has been going on for three days.
Re: Sky box or remote not working
Hi @Yes4   What happens when you press the power button on the Sky Q box?
https://www.sky.com/help/articles/fix-remote
Avatar for Yes4
Level 0 icon
Nothing comes up
Avatar for Yes4
Level 0 icon
There is stuck button and  can't fix it
Hi @Yes4   I'm confused now, button on the box or remote. If nothing happens when you press the power button on the box, then it must be the box? I have provided you with two links, one leads you to a replacement box and the other leads you to a replacement remote.
@Yes4 if its the remote that has the stuck button and you need a replacement remote then follow the link below
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
