Discussion topic: My sky mini box is in setup mode and my control won’t connect so I can set the box up. What do I do!
Message posted on 25 Aug 2024 04:50 PM
My tv is in setup mode on one of my sky mini boxes and the remote isn't connected to it so won't let me setup box.
i have tried the 7&9 and 1&3 process but still will not connect
Message posted on 25 Aug 2024 05:12 PM
Re: My sky mini box is in setup mode and my control won’t connect so I can set the box up. What do I
Hi @Richlouseb Just 7 & 9 should work as that turns the remote into an IR remote which will work on all boxes. Make sure that you can see the box and there is nothing blocking the signal.
Message posted on 25 Aug 2024 06:15 PM
@Richlouseb Have you tried rebooting your Sky Mini Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Message posted on 31 Aug 2024 03:01 PM
Thank you for the advice sky have now sent me a new control and box but in setup mode it says to push home button to finish setup but the control isn't linked to the box! So frustrating!!
Message posted on 31 Aug 2024 03:44 PM
Hi @Richlouseb .
On your mini remote press and hold 7 & 9 on the remote until it's led flashes four times.
This will set the remote to infrared mode which will work all boxes in line of site.
Reboot the mini again and then see if the remote will get past step 1.
Remember to point the remote at the mini .
If you can get the mini working then repair the remote by pressing 1 & 3 and following onscreen instructions.
