Discussion topic: Sky sports UHD
Message posted on ‎31 Aug 2024 02:35 PM
Sky sports UHD
Is this UHD picture any better than HD cos the UHD picture seems to be very dark. 🥴
Message posted on ‎31 Aug 2024 02:49 PM
Re: Sky sports UHD
That's typically a result of the television set not being able to handle the flavour of HDR which Sky uses particularly well.
What make and model is it?
Message posted on ‎31 Aug 2024 03:10 PM
Re: Sky sports UHD
UE43CU8500KXXU Samsung
Message posted on ‎31 Aug 2024 03:21 PM
Re: Sky sports UHD
Hi @Mackemholic Try changing the picture resolution to 2160p 8bit. If that is brighter then you either don't have a HDR box or your TV cannot handle HDR well.
