Discussion topic: I need a sky engineer as my second box is not working
Message posted on 31 Aug 2024 03:57 PM
Message posted on 31 Aug 2024 04:01 PM
Re: I need a sky engineer as my second box is not working
Hi @Evie11
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Reboot the mini as above.
