Discussion topic: My sky keeps freezing
This message was authored by: Lolaskye1
Sky keeps freezing, doing my head in. £150 pcm and can't even watch  first game of the season 😡
Re: My sky keeps freezing
@Lolaskye1  It's likely to be a dish issue, however a reboot can also resolve minor niggles.
Avatar for Lolaskye1
I'm on sky Q so no dish needed
Sky Q needs to have a dish otherwise it cannot work, do you mean Glas/Stream?
It's on my sky Q in another room. Freezes on both. Usually only does it when it snows but it's a clear sky with the sun out 🤷‍♂️
@Lolaskye1  Try the following:
Unplug both the main box & the mini, plug main Q box back in, allow to fully reboot and you can acess the TV guide, then repeat with the Q mini.
