Discussion topic: My sky dish has been knocked can I realign it myself?
This message was authored by Van+Zandt This message was authored by: Van+Zandt
Scaffolders have moved my dish out if place
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: My sky dish has been knocked can I realign it myself?
Probably not.  But you can try and see if you're 'lucky'.
(Alignment is performed with a meter to ensure the signal is correct)
@Van+Zandt
The fine adjustment to elevation, azimuth and skew is likely to be impossible without access to a Q-compatible signal meter.  If above ground level there's obviously also some element of risk involved, so really not advisable.
Note that the cheap meters available online are typically compatible with Sky+ / Freesat LNBs but not Sky Q
