Discussion topic: Best Sky Product for wireless connection?
Message posted on 30 Jun 2023 03:49 PM
I'm having Fibre installed, but to avoid significant disruption to the house we're having the phone line moved to a place where the Sky Box can't be connected to an ethernet cable. The box I have doesn't have the ability to connect to wifi wireless.
What's the best Sky TV product to connect the TV to Wifi without an ethernet cable?
We want to record programmes so guessing Sky Glass and Stream are an immediate 'no'. Any good suggestions?
Message posted on 30 Jun 2023 03:52 PM - last edited: 30 Jun 2023 04:00 PM
Re: Best Sky Product for wireless connection?
Sky Q is the only current product with local recording capability.
The default Sky Q main box is a 1TB unit capable of UHD with HDR.
Message posted on 30 Jun 2023 04:11 PM
@HKF11111111111 wrote:I'm having Fibre installed, but to avoid significant disruption to the house we're having the phone line moved to a place where the Sky Box can't be connected to an ethernet cable. The box I have doesn't have the ability to connect to wifi wireless.
That'll be Sky Q then
