Discussion topic: My sky aerial with the metal pin wont connect to my new sky q box,
This message was authored by Emmsiewemmsie This message was authored by: Emmsiewemmsie
The lead that comes from my dish into my house where my telly is, I think its for the sky aerial , it has a pin in it and you connect it to your sky box. Mine won't connect, it says to turn it clockwise, it's doing nothing at all. Can anyone help me, what am I doing wrong?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: My sky aerial with the metal pin wont connect to my new sky q box,
What do you mean by new Sky box?  Sky usually fit them...
post a picture of this lead.
I am just another Sky customer and my views are my own
hi @Emmsiewemmsie
Does the connector look like F-plug & on the lead top right in this ?
F ConnectorsF Connectors
Do you have 2 cables (usually joined together) ?  as SKY Q needs 2 from a dish
You mention new SKY Q box - is this one sent to you by SKY as a replacement or something else ?
This message was authored by Chodley This message was authored by: Chodley
You realise you only turn the collar clockwise? They can be tricky as they have very narrow threading.
Not sure what you mean by "sky aerial". It's (they are) from the dish to the box.
