Discussion topic: My sky aerial with the metal pin wont connect to my new sky q box,
Message posted on 20 Nov 2023 07:53 AM
The lead that comes from my dish into my house where my telly is, I think its for the sky aerial , it has a pin in it and you connect it to your sky box. Mine won't connect, it says to turn it clockwise, it's doing nothing at all. Can anyone help me, what am I doing wrong?
Message posted on 20 Nov 2023 08:09 AM
Re: My sky aerial with the metal pin wont connect to my new sky q box,
What do you mean by new Sky box? Sky usually fit them...
post a picture of this lead.
Message posted on 20 Nov 2023 08:09 AM - last edited: 20 Nov 2023 08:12 AM
Does the connector look like F-plug & on the lead top right in this ?
F Connectors
Do you have 2 cables (usually joined together) ? as SKY Q needs 2 from a dish
You mention new SKY Q box - is this one sent to you by SKY as a replacement or something else ?
Message posted on 20 Nov 2023 08:15 AM - last edited: 20 Nov 2023 08:16 AM
You realise you only turn the collar clockwise? They can be tricky as they have very narrow threading.
Not sure what you mean by "sky aerial". It's (they are) from the dish to the box.
