Discussion topic: My sky TV is not working
Message posted on 08 Dec 2024 08:39 AM
Sky TV states technical fault only able to access Netflix no other channels working
Message posted on 08 Dec 2024 09:58 AM
Re: My sky TV is not working
What TV service, do you have, Sky Q, Sky Stream or Sky Glass ?
Message posted on 08 Dec 2024 10:08 AM
Sky Q catch up working but not the usual bbc or stv channels. Internet connected so not sure what has happened
Message posted on 08 Dec 2024 10:20 AM
I have moved this to the Sky Q forum for you.
Message posted on 08 Dec 2024 10:21 AM
If it has been windy where you are then the dish may have been moved slightly. The result would be loss of channels in the guide but internet services working OK.
Is that what you see?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 08 Dec 2024 10:51 AM
As mentioned above.
Are you seeing a 'no satellite signal' error on some channels?
If so, work through the following link and if you cannot solve your issue it will lead to booking an engineer.
