Discussion topic: My sky Q mini box as crashed none responsive stuck on step 1 of 4 cant even connect just frozen.
Message posted on 18 Dec 2023 12:17 AM
Message posted on 18 Dec 2023 05:37 AM
Re: My sky Q mini box as crashed none responsive stuck on step 1 of 4 cant even connect just frozen.
Have you rebooted the main sky Q box first ~ then done the same with the mini box?
Message posted on 18 Dec 2023 07:31 AM
@TONUPBOY wrote:
My sky Q mini box as crashed none responsive stuck on step 1 of 4 cant even connect just frozen.ive resetted box about 10 times changed my batterys a few times with new batterys in my remote and still nothing wont set up no further than step 1 please help me as this is so annoying
Hi @TONUPBOY as suggested by @Daniel0210 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?, rhen do the same with the Mini box?
Message posted on 18 Dec 2023 09:26 AM
And re-pair your remote
Message posted on 20 Dec 2023 04:58 AM
After all the advice i done all of the above and still having the same problem looks like the box as seen its end of days .il have to ring sky up to sort this out thanks everybody for yr help.
