Discussion topic: My sky Q is not connecting with my mini box
Message posted on 22 May 2024 01:31 PM
My mini sky box is not connecting to my sky Q
Message posted on 22 May 2024 02:52 PM
Re: My sky Q is not connecting with my mini box
My 2 mini boxes are not working.
Also there are difficulties with connecting the main box with my home wifi
Message posted on 22 May 2024 03:00 PM
Both my mini boxes are not working
My Main Sky Q box has an intermittant fault with my home wifi
Message posted on 22 May 2024 03:48 PM
Hi @Remiabiola
Reboot the mini as above.
