Discussion topic: My sky Q box
This message was authored by: debra+noble
Message posted on 18 Aug 2023 11:19 PM
My sky Q box
My sky Q box is very hot to touch on top. Not just warm. Surely this isn't normal. It makes our room so warm too.
Find out more
Message posted on 19 Aug 2023 05:01 AM
Re: My sky Q box
Your box is designed to be warm but you should always be able to rest your hand on the top. If you can't, and the box is in a well ventilated position I would suggest disconnecting it straight away and calling Sky.
