Discussion topic: My sky Q box will not connect to my sky wifi - wifi is working fine
This message was authored by: Sinead1989
My sky Q box will not connect to the WiFi router, it will connect to my phone hotspot and the WiFi is connected and working fine.
I have tried reseting everything and following all troubleshooting tips to no avail
Re: My sky Q box will not connect to my sky wifi - wifi is working fine
Hi @Sinead1989
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
