Discussion topic: My sky Q box satellite won’t working
Message posted on 11 Oct 2025 03:44 PM
My sky Q is not working signal my sky won't start working again!
Message posted on 11 Oct 2025 03:48 PM - last edited: 11 Oct 2025 03:49 PM
Re: My sky Q box satellite won’t working
Hi @Howaed Are you seeing "No satellite signal"? https://www.sky.com/help/articles/sky-tv-no-satellite-signal-check-q
Message posted on 11 Oct 2025 03:50 PM
@Howaed
No signal and no satellite signal messages are different…
A ”no signal” message tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
