Discussion topic: My sky Q box satellite won’t working
This message was authored by: Howaed
My sky Q is not working signal  my sky won't start working again!
Lisa A Howard
Re: My sky Q box satellite won’t working
@Howaed
No signal and no satellite signal messages are different…
A ”no signal” message tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
