Discussion topic: My screen tells me ' This programme cannot be recorded'
Message posted on 25 Jan 2025 02:18 PM
My screen tells me 'This programme cannot be recorded ' if I press the record button on my Sky Q remote. The programmes I've tried are all in my package, there is enough space and my wifi is connected...good satellite signal? Any ideas out there
Message posted on 25 Jan 2025 02:41 PM
Re: My screen tells me ' This programme cannot be recorded'
@Sherburn Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jan 2025 09:20 PM
Not sure if this helps, but I had a similar situation when I tried to record an episode from a more recent series that I was following. It was simply showing as "available" to download/watch.
It turned out that the episode was only available in UHD, but I only had a subscription for HD. So was unable to record it. Hence a similar notification.
