Discussion topic: My remote will only switch on TV doesn't work the box
This message was authored by: Doctorbob1
My sky q remote control only switches on the TV it doesn't work the sky q box at all
Re: My remote will only switch on TV doesn't work the box
Hi @Doctorbob1
Try completly resetting your Bluetooth remote.
