Discussion topic: My mini box
Message posted on 19 Nov 2023 07:16 PM
My mini box
My sky mini box is stopping and starting
The picture is freezing. The engineer was out today replaced an hdmi cable but the problem is still there
Message posted on 19 Nov 2023 07:17 PM
Re: My mini box
Reboot the mini as above.
