Discussion topic: My main sky q box is stuck on the orange light and will not turn to green
This message was authored by: WillBlack
Can't watch sky. Main sky w box is stuck on orange light. And therefore can't use sky mini box either
Re: My main sky q box is stuck on the orange light and will not turn to green
Hi @WillBlack
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: BillWalk0705
I need help with this, the amber light won't change at all and I've tried everything from pressing the button on the box itself to changing the batteries in the remote.  Nothings working and I don't wanna unplug it from the source, because I'd lose all the recordings
@BillWalk0705 unplugging your box from the wall socket and plugging it back in will not lose your recordings
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
