Discussion topic: About tv
Message posted on 25 Oct 2024 04:20 PM
About tv
Hi my tv is not working with boardband what i can do plz call me and fix it
Message posted on 25 Oct 2024 04:37 PM
Re: About tv
Hi @Fidahussain
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issues
