Discussion topic: My main box is not working
This message was authored by: Heather17
Message posted on 04 Nov 2023 02:42 PM
Stuck on stanby, can you help
Find out more
Message posted on 04 Nov 2023 03:37 PM
Re: My main box is not working
Hi @Heather17
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
