Discussion topic: 2nd box doesn’t work
Message posted on 04 Nov 2023 02:53 PM
It's saying on the screen there is problem , internet is fine everything is connected
Message posted on 04 Nov 2023 03:36 PM
Re: 2nd box doesn’t work
Hi @Mandyuk
Reboot the mini as above.
