Discussion topic: My box isn’t recording
This message was authored by: Shard
I've tried everything to get my channels to record. Not only that they won't delete?! It's driving me insane what do I do?
Re: My box isn’t recording
Hi @Shard
A simple reboot may fix it.  But if the above doesn't work then it may be an issue with the hard disk that Sky would need to attend to.
