Discussion topic: Netflix ap doesn’t start unless I reset sky box
Message posted on 20 Nov 2023 05:22 PM
Netflix doesn't start unless I restart my box but I have to restart box every time I use Netflix
Message posted on 20 Nov 2023 06:32 PM - last edited: 20 Nov 2023 06:34 PM
Re: Netflix ap doesn’t start unless I reset sky box
Hi @ShaneP
Have you tried a Reset Settings in the Q box hidden menu.
